Post
by ninja6485 » Mon Jan 09, 2017 4:54 pm
Unless a part really needs to be stereo, like a string sound with lots of chorus or stereo effects, it can actually be better for your mix to keep it in mono. This especially goes for bass parts. Panned mono sounds don't conflict with each other as much as you get less masking. So if using the mixer to create a mix, it might be a good idea learn from modeling your tracks based on the way common mixers are laid out.
This of course doesn't help if you're not using the mixer to mix, you just want to have all your gear plugged in at once, and want to be able to power everything on and use it whenever you want without unplugging anything.
I suggest looking for an additional interface that can be chained to work together with what you have (if possible) to give you the proper number of inputs, and then look into mixing desk style midi controllers, if they exist, and use that to control what's happening ITB.
Another idea would be to find a mixer with group's tracks that each get dedicated channel strips, and then you can have a massive set of left/ right moni pairs set up on the desk, and when you want to mix with them, have each pair assigned to a group. If you find a mixer with 4 stereo tracks and 4 group tracks, you can use the group tracks as 4 additional stereo tracks, each with a pair of mono tracks sent to it.
For example, my Yamaha MG mixer is fairly basic, but has 4 stereo tracks, and one additional group track. So if I take mono tracks 3 and 4, pan them hard left and right, and then send them to the group (keeping everything else going to the stereo bus); I can now use the group fader as a dedicated fader for that stereo pair, giving me 5 stereo tracks and two mono track's total.
The mixer also has an RCA in, which while not a stereo track, does allow for the input of an additional stereo input source, which can be panned compressed and equalized externally, giving a total of 6 stereo inputs and 2 mono inputs on the mixer. The last one's fudging it a little, but you get the point. There's also daisy chaining mixers, but that can take up a lot of space!
My particular mixer does not meet all your requirements, but I'm sure there are some that are - possibly even digital mixers!
