Unidentified Binson echo unit (fixed image)
invisiblea
Post by invisiblea » Mon Aug 26, 2019 7:31 pm
Hello,
Apologies if this is the wrong place, but...
Does anyone know what this is?
I know it's a Binson echo unit, but I can't find any other images or info about it on the internet. I saw it in a flea market in Italy, and decided to take a photo and do some research on it before buying it. I spent too long trying to find out what it was and the market had closed before I went back to get it.
Any help appreciated.
Alex W
Broadwave
Gear:Kronos 2-88, Fantom 6, Novation Summit, ASM Hydrasynth, Modal Cobalt8, Behringer Odyssey, Behringer Poly D, BroadWAVE ARP 2600EX.
Re: Unidentified Binson echo unit (fixed image)
Post by Broadwave » Sat Aug 31, 2019 2:31 pm
Good lord, I've not seen one of those since the 70's. The one I had wasn't made by Binson, but it looks almost the same. :o
The disc that you can see is a custom coil of recording wire (no tape), the record and playback heads are arranged around the disc to provide the effect... It's going to be hit-and-miss if it works and almost imopossible to get a new disc.
I upgraded to an HH slide tape loop echo which I still use ;)
