Korg DS8 Sound Problem
jackvonthor
Post by jackvonthor » Tue Aug 04, 2020 5:54 pm
Hello
Recently I bought used Korg DS8 and I am having some problems.
The sound that is coming through the output is.. messed up, sounds glitchy.
As a Midi Keyboard, it works without any problems. (through USB-> Midi adapter)
I recorded a video with the issue:
Maybe someone knows what could be wrong? I would be really grateful for any hints.
Thanks
jackvonthor.
Virgule
Re: Korg DS8 Sound Problem
Post by Virgule » Wed Aug 05, 2020 8:02 pm
Hi,
Is the display okay or are there any funny characters?
Have you done the factory reset? : Hold up and down, then power on.
jackvonthor
Post by jackvonthor » Thu Aug 06, 2020 11:27 am
Display is ok, everything is displayed properly.
I tried to do the reset, but that didn't help
Virgule
Post by Virgule » Thu Aug 06, 2020 5:32 pm
Does this sound similar to your issue?
http://forum.vintagesynth.com/viewtopic.php?t=47717
Ignis
Post by Ignis » Tue Feb 09, 2021 6:17 pm
Can you still create a patch?
If not, could it be all your presets are messed up? If that is the case, you may have to replace the back up battery inside and then reload via MIDI Sysex the factory presets.
jackvonthor
Post by jackvonthor » Tue Feb 09, 2021 6:23 pm
Hello
I did just like you said. Now everything works like a charm ;)
Thank you!
Ignis
Post by Ignis » Tue Feb 09, 2021 9:19 pm
Great to be able to help.
You can close your topic finally! :)
