Kurzweil K2500 operating system bugs?
ʝɵʝɵ
- Junior Member
- Gear:Roland D-50, JD-800, R-8, U-220, XV-5080, Yamaha AN1x, CS6R, TG77, Korg Triton Rack, Wavestate, X5DR, Kawai K4, Kurzweil K2500, Ensoniq SQ-R Plus/32
To add some closure to this topic, after being able to test this on another K2500 I was able to confirm that it's not just my unit. In OS version 2.99 the bug doesn't exist, only in 3.02. The latest KDFX OS version is also affected.
- Mesmerised
- Real name:Chris
- Gear:Minimoog, ELKA Rhapsody, MFOS Modular, TTSH, Matrix 1000(2x), K5000S, MI Ambika(2x), Shruthi (3x) and Anushri, Sonic Potions LXR, JX-8P, D-50,...
- Band:Palantir
Re: Kurzweil K2500 operating system bugs?
I have a K2500 with SMCTLV7 and latest KDFX OS and objects installed. So far it does NOT show this behaviour. The Space Station Patch for instance plays fine without glitches.ʝɵʝɵ wrote: ↑Sat Sep 23, 2017 7:26 pmAfter obtaining a K2500 with OS 2.80 installed, I wanted to install the latest version, 3.02 (for non-KDFX units), which I downloaded from the Kurzweil website. While it seems to work in general, I noticed that now some patches behave strange. For example program 891 - SpaceStation sometimes introduces little noise bursts into
EDIT: OK - strange... After power cycle "Space Station" also has rare clicks on my unit. (OS 5.01)...
Obviously this does not happen every time.
ʝɵʝɵ
- Junior Member
With the Space Station patch it may depend a bit on how you play it. But with this patch you should always hear the clicks, as they no longer depend on note velocity and other factors.
