ARP 2600 attack and release
my roomate has an arp 2600. the filter for the attack and release never closes. you can control it manually but otherwise it makes it almost useless. im sure its just capacitors but if i get the schematics i wouldnt even know where to look for anything. you guys are usually pretty helpful with the information you give out so ny advice would be great.
- hfinn
- Expert Member
- Gear:http://soundcloud.com/heath-finnie
The Filter section has only direct sliders for the ADSR Envelope and VCO2. The AR and ADSR Envs are hardwired to the VCA. Therefore. the AR would have to be patched to the filter to do what you are saying. Are you saying the ADSR is not working on the filter or is th AR not working with the VCA? Try patching around to test these sections.
Buchla, Serge & Eurorack Modular; EML101; Minimoog; Synthacon; MS20; Nord2; NordG1; PolyEvoRack; MKS80; MKS50; TB303; Electribe EMX1; JV1080
http://www.REwireMusic.com
